Order Farmall Cub Parts Online
Cub motor?
Jim in Ma.
01-16-2008 16:27:28
just wondering, Will a cub 154 motor fit in a 1950 C60 Cub? mine is getting tired and I need to do that or a rebuild. This is a working tractor not for show. Thanks for any input Jim
mkirsch
01-17-2008 05:57:30
 Re: Cub motor? in reply to Harold H, 01-16-2008 16:27:28
Unless your transmission is so worn out that it's ready to fall apart, the HP increase won't hurt it one bit.
billde
01-17-2008 05:51:01
 Re: Cub motor? in reply to Jim in Ma., 01-16-2008 16:27:28
If the engine is out of an early 154 the HP is the same. No need for concern anyway, it's a 4 HP increase.
Bigdog
01-16-2008 18:55:06
Yes, but not without some changes. The flywheels are different and if I recall correctly, the end of the crank is not drilled for a pilot bushing.
It's not just a bolt-in swap.
Jim in Ma.
01-16-2008 20:37:29
 Re: Cub motor? in reply to Bigdog, 01-16-2008 18:55:06
Thanks bigdog: I'm fearful that the transmission won't hold up with the added power.
