are all F-20 decals the same??
Russ926
01-16-2008 17:33:28
My f-20 is a 1935. being (grey), would the same decal be used as for example 1937 (red)??
Farmallgray
01-17-2008 14:50:54
 Re: are all F-20 decals the same?? in reply to Russ926, 01-16-2008 17:33:28
Russ,
There wasn't really any difference from the gray to red tractors, except some additions, and omitions. If you get a set from any of the decal suppliers, you should get all the decals you need. But, You may not need all the decals in the kit.
IMO, The supplier that makes decals closest to original is Maple-Hunter decals. Although nobody at this time makes exact decals like the tractors came from the factory with.
This book should be a big help to you;
Scott Rukke
01-16-2008 18:32:23
I believe there's a difference in the decals depending whether it's a narrow tread or regular tread.
Russ926
01-16-2008 18:40:38
 Re: are all F-20 decals the same?? in reply to Scott Rukke, 01-16-2008 18:32:23
I understand the narrow tread. Mine is just a plain ol farmall. Not narrow, not a regular.
