C hydrolic pump serial numbers
Johnny D
01-16-2008 18:40:04
Trying to figure out which number identifies the correct hydrolic pump for my 1950 C. Here are the numbers I have been able to obtain:
350707R96 or 360707R96 the second # is not clear
Also these numbers are stamped on the pump:
322531 and 05101208002
Can anyone tell me whether this is an original hydrolic pump for this C I need to order a front seal but want to make sure I identify the pump correctly. I have heard that many were changed and that some newer model pumps will work
El Toro
01-17-2008 06:14:34
 Re: C hydrolic pump serial numbers in reply to Johnny D, 01-16-2008 18:40:04
third party image
Here's a parts breakdown on those hydraulic pumps.
Hal
gene bender
01-17-2008 04:12:24
You need to take the pump off. Never mind about the # you first have to take pump apart to check the surface of the shaft where the seal rides as you probably will need a speedy sleeve on the shaft then you can see which seal you need so take it off and get started.
Johnny D
01-17-2008 19:05:26
 Re: C hydrolic pump serial numbers in reply to gene bender, 01-17-2008 04:12:24
Thats what I have heard. Thanks.
Jim Becker
01-16-2008 19:31:51
350707R96 is a Pasco pump. It may be a later revision from what was used in 1950. Doesn't matter. The seal should be 353183R91 for any of them.
