what does it do? how does it work?
funtime
01-17-2008 02:58:20
just pirchased a 48 cub. the knob by the amp guage and push/pull switch has no decals, and i was wondering how to operate it during starting and during operation. thanks.
Bus Driver
01-17-2008 07:06:01
 Re: what does it do? how does it work? in reply to funtime, 01-17-2008 02:58:20
An owner's manual would be very helpful for you. YT may offer some sources.
mkirsch
01-17-2008 06:04:04
 Re: what does it do? how does it work? in reply to Andy Motteberg, 01-17-2008 02:58:20
The push/pull switch is for your ignition. Pull it out before you start the tractor, and push it in when you want to shut the engine off. The person that sold it to you should have shown you that if you bought a running tractor.
The knob is the charging/light switch. On a stock 1948 Cub the first two positions are low charge and high charge. The third and fourth positions are dim lights and bright lights. Right after you start the tractor, you should have it on high charge. After a few minutes, you can turn it back to low charge.
If the knob goes click-click-click when you turn it, you have a four position switch. If it only goes click-click, it's a 3-position switch.
funtime
01-21-2008 01:51:24
 Re: what does it do? how does it work? in reply to mkirsch, 01-17-2008 06:04:04
the tractor runs nice. this switch was bypassed and the harness is a mess. i got both ordered and on the way.
funtime
01-17-2008 13:40:24
the poor little thing runs. lots of neglect. the harness is a mess. will be replacing it. thought i would ask while waiting for parts. thanks for the info. probally more questions to follow before im done with the restoration.
billde
01-17-2008 05:58:34
The push pull switch is the ignition switch. Out is run, in is off. If it has a mag, in grounds the mag to kill the engine, out is run.
Steven f/AZ
01-17-2008 04:50:52
If it has 4 positions it goes from left to right: Low, High, Dim, Bright - Low and High are the charge rates, Dim and Bright are for the lights.
If it has 3 positions, it's just a light switch: Off, Dim, Bright.
GooseCreek Farms
01-17-2008 03:19:59
I believe it is the fuse. Push it in and turn it and it will come out and you will find a fuse attached to it.
funtime
01-17-2008 04:24:51
 Re: what does it do? how does it work? in reply to GooseCreek Farms, 01-17-2008 03:19:59
this is a 3 or 4 position switch and it does have a fuse with it. i'm hearing it has something to do with charging.
