Farmall Lights
GARRY_TENN
01-17-2008 03:24:32
I juat bought 2 new frontlights for my Super H. They were shipped wihout the C shaped clamps that fasten the lights to the cross piece. Any suggestions as to where I can buy the clamps?
Also where on the block is the engine number? They all start with a C as far as I know. What is the engine number for a Super H?
Thanks
pat in wis
01-18-2008 16:21:08
 Re: Farmall Lights in reply to GARRY_TENN, 01-17-2008 03:24:32
the motor serial number will be Stamped into the block on a raised part of the casting below # 3 spark plug ( kinda by the oil filter top )
It will have a Cast number of C-164 also.
Hope this helps
Pat
dave guest
01-17-2008 18:46:38
Sounds like a low tar cigarette for farmers.
Wayne in MN
01-17-2008 16:23:44
I have several; do you need the cast clamp or stamped steel style? How about spacers?
E-mail is open.
Dave H (MI)
01-17-2008 07:03:25
I think I have one....but only one.
CityBoy-McCoy
01-17-2008 05:03:41
You can buy the clamps at O.E.M. tractor parts, or used at a tractor junkyard.
Super H engine serial numbers are on a milled flat surface in line with #3 cylinder. mike
RustyFarmall
01-17-2008 05:29:25
 Re: Farmall Lights in reply to CityBoy-McCoy, 01-17-2008 05:03:41
there is also a number cast into the block, somewhere in the area of where the oil filter sits. A Super H will have C-164.
