super c crank question?
mixaplix
01-17-2008 13:50:25
hello, on the rear seal end of my c crank there is a groove,(sort of looks like a spiral)It does not look to be worn in but actualy made that way to keep some oil on the seal. If I am right would the seals in modern rebuild kits work o.k. or would it be a idea to have the surface made smooth? thanks in advance
gene bender
01-17-2008 14:03:55
 Re: super c crank question? in reply to mixaplix, 01-17-2008 13:50:25
When you get your gasket set there will be new pieces of felt to replace the old ones so just leave the crank alone
