Super C Charging Problem
Mike Layden
01-17-2008 15:36:41
I have a Super C somewhere between 1949 and 1953. I can't seem to keep the battery charged. It's 6 volt positive ground. The generator is good regulator is fine. I polarized the regulator. The amp gauge showed charging for maybe two hours then went back to 0 and stayed there until the battery was finally dead. we've tried to polarize the regulator again after taking the battery out to charg it but to no avail Help Thanks Mike
Janicholson
01-17-2008 21:05:49
 Re: Super C Charging Problem in reply to Mike Layden, 01-17-2008 15:36:41
John T has a posted charging system diagnosis list. It is great, look for it in the Search for box. JimN
JFavor
01-17-2008 16:48:16
Run a jumper wire from the field terminal on the generator to any ground. If it charges the generator is good. Regulator bad. If not. Probably a bad generator.
