1206 Oil and Water
rdw
01-17-2008 17:32:34
I have a 1206 IH that has water in the oil. They are bubbles in the rad. when runing.Blowen hear gasket??? If not what???? Thanks wolfe
TractormanNC
01-18-2008 07:13:41
 Re: 1206 Oil and Water in reply to rdw, 01-17-2008 17:32:34
1206 has dry sleeves. If you see water dripping from the bottom of a sleeve you have much worse problems than a blown head gasket.
KJFarms
01-18-2008 05:42:58
Can be series of things. I'm going through the same thing right now. Has the tractor been running hot? If you have a cooling system pressure tester. Put about 18-20 psi to the cooling system, and pull the oil pan. Look for water dripping from the cam shaft side of the engine. If you see water drips it's head gasket. If you see water drips from the bottom of the sleeve, its a sleeve problem. Hope this helps.
anthony basinger
01-17-2008 18:32:07
Yeah sounds a lot like blown head gasket.
