Explain This?
Allan In NE
01-18-2008 06:17:22
I've heard people say that the wide fronts can't cross the SM,400 boundry to the 560s and newer.
How come?
The only difference is the "height/length" of those 4 mounting bolt bosses. Right? "Spacing" is still the same, isn't it?
Always wondered about that.
Allan
Tim Shaw
01-18-2008 14:02:06
 Re: Explain This? in reply to Allan In NE, 01-18-2008 06:17:22
I think most of the differences are in the rear saddle and the steering arm. We put one off of an M on a 460 and just had to change the rear saddle. The following link shows the differences.
Link
Iagary
01-18-2008 09:46:54
Allan all the bolt holes will line up.
But the height or plane that those 4 bolts under the front end are on are not the same height in relation to the frame rails.
Can't remember which one is higher, the M or the 560. But if you take it off one to put on the other you have to space between the front end and the bolster. And going the other way you have to space between the frame rails and the rear mounts bracket.
I think to put a wide front on the M, off of a 560, you have to space the frame rails.
Gary
Iagary
01-18-2008 10:27:28
 Re: Explain This? in reply to Iagary, 01-18-2008 09:46:54
I was backwards. You would have to space those 4 front bolts down 2.5" to put a wide front from a 560 to a M.
Check the pictures above.
Gary
Harold H
01-18-2008 08:24:23
They will fit. They have differences but they will fit.
Harold H
the Unforgiven
01-18-2008 06:29:45
Isn't there a length difference in the wishbone and bracket assembly?
RustyFarmall
01-18-2008 06:21:39
I am under the impression that they WOULD interchange, but I've had no actual experience.
RustyFarmall
01-18-2008 06:33:44
 Re: Explain This? in reply to RustyFarmall, 01-18-2008 06:21:39
My catalog does show different part numbers for the complete assembly. It also shows that the price has gone up.
