Rear tire size for an M
Patrick Martin
01-18-2008 08:17:33
What is the rear tire size for a Farmall M????? ??? I need to order a set and dont know what size I need.
CNKS
01-18-2008 18:19:47
 Re: Rear tire size for an M in reply to Patrick Martin, 01-18-2008 08:17:33
IH offered 9,10, and 11 inch rims for 10(11.2), 11(12.4) and 12(13.6) inch tires. They also list 13(14.9) for the same rim as the 12 inch tire. From the factory, 11 or 12 inch were likely the most common. If I had to guess, I would say 12(13.6) inch is the most desireable size today, but as noted you see about everything.
Patrick Martin
01-18-2008 08:35:51
Thank you much sir :D !!!!
Andrew Z
01-18-2008 09:32:41
 Re: Rear tire size for an M in reply to Patrick Martin, 01-18-2008 08:35:51
Just as a side note to Rusty, 12.4's (11-38 old size) would have been the factory size for the M. but 13.6's work really well on them to all depends on your preferences.
Andrew
RustyFarmall
01-18-2008 08:27:46
13.6 X 38 is the most common, but quite a few have been changed to 14.9 X 38, and some Ms even have 15.5 X 38. The 14.9 will fit on the same rim as the 13.6, but the 15.5 needs a wider rim. You really need to go look at your tractor and see what is on it now.
