SMTA again
Larry NCKS
01-19-2008 13:31:59
Well guys, I gol dern gone and done it. I'm normally on the Ford board, but - - - the poor guy spent an hour and a half in near zero weather getting it started, so I had to buy it didn't I?
Is there a good source for replacement parts for SMTAs other than CIH? For instance where can I get an original battery box for under the seat? Wiring harness and original gauges, etc.?
Is there a really good source for a TA other than CIH? Thanks!
Kevin Meier
01-19-2008 18:53:28
 Re: SMTA again in reply to Larry NCKS, 01-19-2008 13:31:59
I probably have a ta on hand. Shoot me an email if you are interested. I"ve been building them for 15 year and they come with a full warranty
Dave S.
01-19-2008 17:21:36
Try Mike at Steel Wheel Ranch PH# 785-548-7437
oldiron29
01-19-2008 17:18:44
Larry, I would think that OEM would have some of the battery box. Steins would have the gauges and Brillman Co. would have the wireing. Oldiron29
Larry NCKS
01-19-2008 16:55:21
 Re: SMTA again in reply to georgeky, 01-19-2008 13:31:59
I already looked here. If it was here, I didn't see it. But thanks.
CNKS
01-19-2008 18:50:11
 Re: SMTA again in reply to Larry NCKS, 01-19-2008 16:55:21
You can get all that except the TA from OEM Tractor Parts, or better Mike at Steel Wheel Ranch -- he is in NE KS at Everest, you might even want to drive over there, particularly if you want a TA, he has that too. Most of the other parts he will have drop shipped from the manufacturer, not sure if he actually keeps the TA's or not.
RustyFarmall
01-19-2008 14:13:12
Try right here on YT first. I think you will find just about everything you mentioned. I sell the same stuff, but if you buy from this site, it might help keep this forum running.
