Order Farmall Cub Parts Online
cub distirbutor question
jk
01-19-2008 15:01:45
i was wondering if anyone can tell me where to find the distributor number on a 54 farmall cub. also the housing on the distributor is worn, would updating to electronic igntion fix the problem of the point gap always changing. thank you
NawlensGator
01-20-2008 06:39:57
 Re: cub distirbutor question in reply to jk, 01-19-2008 15:01:45
I used a hex head bolt to help stop the points from slipping on one of my 140 tractors. It helped but they still worked loose and had to be reset. Electronic ignition was the FINAL solution. I just removed the points etc from our cub and installed electronic ignition last week. This is the 3rd tractor I've installed EI on and I recommend it. Be warned the correct police won't approve.
Jim in Ma.
01-19-2008 18:00:08
my book shows # 353 893 R91 I hope this helps
