tractor stops
Travis hoffmeie
01-20-2008 08:46:33
I have a question When i start up my farmall super a (1947) after about 2 hours of constant running it tries to shut off when i go to shift into a new gear? when i start to let the clutch out it sputters and then it will shut off. Can you help me? I think the problem is in the eletrical in general.
old
01-20-2008 09:53:25
 Re: tractor stops in reply to Travis hoffmeier, 01-20-2008 08:46:33
Best way to figure it out is run it till it stops. Then check for spark and fuel. Pull the coil wire and see if you have spark. If you have spark then it has to be a fuel problem. If you don't have spark I would start out by trying a new coil.
Tarvis
01-20-2008 14:41:19
 Re: tractor stops in reply to old, 01-20-2008 09:53:25
ok thxs the tractor is all greasy i was going to try to degrease it with a power washer this summer and do body work to it is there any chance it could be grease or crud blocking something
old
01-20-2008 15:05:34
 Re: tractor stops in reply to Tarvis, 01-20-2008 14:41:19
If it runs fine then dies nope it not the grease but something like the coil going bad or loosing gas flow
CNKS
01-20-2008 09:13:51
Coil or condensor. Or a piece of crud floating around in your gas tank that eventually blocks the inlet.
CCer
01-20-2008 08:56:52
Carefully examine your tractor's wiring, I've had wires that moved ever so slightly and touched a short/ground. When I moved something, hit a bump etc. the power was cut off.
