McCormick Deering 1925 10/20 PARTS NEEDED
Mark Olson
01-20-2008 09:53:48
I'm trying to rebuild a McCormick Deering 1925 10/20. I need cyclinder sleeves, pistons, rocker arms, push rods, crank barrings, and all air cleaner parts.
I'm looking for a motor rebuild kit. If anyone has any parts or information where to find them please contact me at (425) 308-9510.
James Williams
01-20-2008 11:09:56
 Re: McCormick Deering 1925 10/20 PARTS NEEDED in reply to Mark Olson, 01-20-2008 09:53:48
F30 has the same motor parts,They are very expensive,and are not being made,Most of the time sleves can be honed and new rings installed,Shims can be removed for rod bearings to fit.Rice equ.has a lot of parts
jimmy
El Toro
01-20-2008 10:51:51
Webers tractor works has a set for the 15-30 they may have a set for the 10-20. I don't know if that 15-30 set will fit your block I doubt it.
You can call them at 815-389-1493. Rice Equipment
in PA may have set. Call them at 814-226-9200.
LA Sleeve can probably make a set since you have the old sleeves call 1-800-822-6005. Hal
