McCormick Deering W-6 W-4 Top Speeds?
LANZMAN
01-20-2008 16:00:46
What Are The Top Speeds For A McCormick Deering W-4 & A McCormick Deering W-6?,(Both Standard Models)
ejr-IA
01-21-2008 17:48:36
 Re: McCormick Deering W-6 W-4 Top Speeds? in reply to LANZMAN, 01-20-2008 16:00:46
Neb. state test reads W6 at 161/8 mph W4 15 mph.
CNKS
01-20-2008 17:10:36
I don't think IH intended to make the speeds exactly the same. Tillage gears are about 1/4 mph slower than the H or M. 5th in the W4 is 14 mph or slightly more than 1 mph slower than the H. W6 is 14.5 mph or almost 2 mph slower than the M. These are factory specs, they can change significantly depending on tire size.
randy hall
01-20-2008 16:23:27
the the transmission gears are same same as their counterparts the h and m. the ring and pinion ratios are different to make up for the smaller diameter rear tires. this gives them the same ground speeds as the h and m.
billde
01-20-2008 16:16:11
Don't know if the gears are the same but I had an ID-6 that would outrun the 806D, and by a fair margin.
Yugrotcart
01-20-2008 16:05:04
About 16 mph for the W6. Plenty fast enough.
I imagine the W4 is about the same.
Paul
LANZMAN
01-20-2008 16:11:33
 Re: McCormick Deering W-6 W-4 Top Speeds? in reply to Yugrotcart, 01-20-2008 16:05:04
Thank You Very Much
