farmall A - oil pump question
nspec
01-20-2008 16:09:00
So I"ve got the oil pump out of my A, and I"ve got the cover plate to the pump which I would like to resurface so as to restore a little oil pressure. I"ve read here in the past to put a piece of sandpaper on a piece of glass so it will be perfectly flat and then wet sand it down.
My question is, how fine should the sandpaper be? Also, I was thinking maybe I could use lapping compound right on the glass with no sandpaper? Would I end up with fine glass everywhere?
Thanks in advance for the help!
john *.?-!.* cub owner
01-20-2008 19:34:27
 Re: farmall A - oil pump question in reply to nspec, 01-20-2008 16:09:00
Have you checked the crank and bearings? They are usually a bigger cause of low oil pressure than a worn pump.
Dave Sherburne NY
01-20-2008 19:31:56
Did mine on the cast iron table saw table
scott#2
01-20-2008 17:10:04
Depending on how worn it is, I start witha 260 or so grit and finish it off with a 400, then 600 grit piece. Just take it down to where the gear marks dissapear, maybe more if it looks like their might be a sealing problem where the gasket goes. Make sure your gear to cover clearence is right, think .003 - .008 or so. I like .004 with the thick gasket and hi tack sealer. You may need to hoen the gear face of the non driven gear a bit if it shows circular groovs. Most of those plates are pretty warped and it takes a good bit of time measuring and honing to get it right.
scott#2
