Fender Brackets
Chris450
01-20-2008 16:30:09
I was wondering what the length is for the pipes that go under the fender bracket to raise it up off of the axle housing. It is on a 450.
Also I was wondering how much a belt pulley gearbox is worth for a 450 diesel. Will this fit on a Super MD.
SDE
01-21-2008 16:53:11
 Re: Fender Brackets in reply to Chris450, 01-20-2008 16:30:09
I am going to guess that they were about 1-1/4" long. Maybe they were only 1 inch.
They are long enough to provide enough clearance to go over the hitch to axle bolt, which is at least 3/4".
It is to cold for my lazy butt to go outside.
SDE
Lynn Davis
01-21-2008 11:21:37
Can't help with fenders, but pulley for an M through 660 should work.
Zach Bouchard
01-21-2008 07:49:09
If the 450 pulley doesn't fit one off an M will.
