Order Farmall Cub Parts Online
Re: 48 cub mag.
john *.?-!.* cu
01-20-2008 19:48:52
funtime said: (quoted from post at 17:58:02 01/16/08) my little operators book didn't show up yet. so i'll ask this one. what is the function of the 3 or 4 position switch next to amp and on/off push/pull switch. my decals are missing, and what position should this be in while running. thanks.
That is the light switch. On the 4 position one it also controlled the charge rate. Lo charge, Hi charge, Dim lights, Bright (actually less dim) lights. The 3 position was on tractors with a voltage regulator and was Off, Dim, Bright.
