Order Farmall Cub Parts Online
Cub Carburator I.D
Mifsud
01-21-2008 13:01:59
Rebuilding the carb on my 1949 cub. Problem is the only markings on it are the IH. All my other carbs. on Farmalls are marked with #s. What kit do I need to order and who has them? Thanks
Jim Becker
01-22-2008 19:50:52
 Re: Cub Carburator I.D in reply to Mifsud, 01-21-2008 13:01:59
Looks like you may have mixed the digits after the R, but that is an original 3/4 IH Cub carburetor. Gene gave you the part number of the rebuild kit.
Mifsud
01-22-2008 10:52:24
Gene, Just found the # as you said on top of carb. They don't match up with your #s. mine reads 251234 R19 . Any ideas?
Gene
01-21-2008 20:12:14
There are two IH carbs for the Cub. 3/4" ventura (throat) and 1" ventura. The 3/4" carb is supposed to have a part number stamped on the body assembly (top/cover), flat area to the left of the fuel intake.
The carb kit available from your IH dealer is the best. There is a carb kit available at your local autoparts store.
IH#, 3/4" kit #: 354 454 R92
IH#, 1" kit #: 368 357 R91
You might want to double check the kit numbers with your IH dealer.
