Starter interchange????????
Bilko
01-22-2008 13:36:00
Can anyone tell me if a starter from an Farmall A will work on a Farmall B. Thanks for your time.
gene bender
01-22-2008 18:30:56
 Re: Starter interchange???????? in reply to Bilko, 01-22-2008 13:36:00
It will work just fine as they are the same just bolt it up and go the starter sw is the same operated by the same pushrod. Just change it and go.
NDS
01-22-2008 17:01:02
All non super non diesel letter seies Farmall starters will interchange as far as bolting on the differenceis is in electrical switchs and electrical hook up. The A,B and C starters are not as powerfull as H and M starters(I think not sure though).
RustyFarmall
01-22-2008 13:37:52
Should be a direct swap.
Bilko
01-22-2008 15:24:34
 Re: Starter interchange???????? in reply to RustyFarmall, 01-22-2008 13:37:52
I was thinking it should be but was not 100% sure.
Thanks for the information RustyFarmall.
