Ballast Resistor
Justin S. - TX
01-22-2008 18:21:17
Does anyone have a part number for an external ballast resistor, I have a C I converted to 12 V, and the one my Case dealer sold me was wrong.
dave guest
01-23-2008 17:15:36
 Re: Ballast Resistor in reply to Justin S. - TX, 01-22-2008 18:21:17
Guess if that happened to me I would be back at dealer, asking for refund, explanation, or both. Its there JOB.
El Toro
01-23-2008 08:00:43
Here are the part numbers on the ballast resistor
and on the 12 volt coil with the builtin resistor.
I would go with the coil IC14SB for about $15.00. Hal
ECHICR13 on the resistor
MN Mike
01-23-2008 05:41:28
I took the $4 option last spring when I converted my tractor to 12 volt. I'm saving the more expensive solution until I need it.
Justin S. - TX
01-23-2008 11:11:32
 Re: Ballast Resistor in reply to MN Mike, 01-23-2008 05:41:28
Thanks guys, got one at my local NAPA, I'll put it on tonight. Thanks again
SD FARMALL
01-22-2008 22:42:08
I have to agree with Fancy Farm if your gonna convert just convert to the 12v coil will save ya the headache down the road for when the resistor goes out.
glennster
01-22-2008 19:10:04
stop over at a napa auto parts store, have them get you a ballast resistor for an early 1970's chrysler b body. it is a real nice ceramic resistor, cost maybe 4-5 dollars. has a single mount bolt in the center.
Fancy Farm
01-22-2008 18:41:55
For what it is worth you can get an internally resisted 12 volt coil at napa and not use a external resistor.
