Steering wheel nut on SMTA
RBTXS
01-22-2008 19:39:21
What size is the nut that holds the steering wheel on a SMTA? Also, is it a fine thread one?
ejr-IA
01-23-2008 13:16:51
 Re: Steering wheel nut on SMTA in reply to RBTXS, 01-22-2008 19:39:21
3/4-16 nf
Andy in Beloit
01-23-2008 11:15:34
If you want to dress it up a bit, I replaced mine with a 3/4" fine thead ss acorn nut and washer. I had to special order the nut from Fastenal ($10) and grind the o.d. of the washer to fit the steering wheel hub, but if you're not worried about keeping it original or spending a few extra bucks it sure looks sharp.
GordoSD
01-23-2008 06:00:56
My IH dealer has them.
Gordo
TractormanNC
01-23-2008 05:13:02
3/4 fine thread JAM nut. Standard hex nut will be too thick. Any good nut and bolt place should be able to fix you up, maybe even a local hardware store.
Randy in NE
01-23-2008 05:02:13
I looked at the parts manuals for the H through MD and the SM and SMTA. They show the steering wheel but not the nut. I had to replace the one on my C a couple of years ago. It seems like it was about a 3/4" fine thread. I would guess that the SMTA would be about the same size. I had to use an impact wrench to remove the nut and a puller to get the steering wheel off.
