Super A transmission, ball bearing removal
Hendrik
01-23-2008 01:36:18
I’m in the process of replacing the transmission bearings of my Super A. The pin through the reverse spline gear was removed and I moved the spline shaft (upper, or input shaft) towards the rear by about 1 inch. (Both ball bearings still on the spline shaft, just clear of their bores.) As a next step, I guess, I have to remove the ball bearing from the front end of the spline shaft. How can this be done? The Service Manual says “drive the shaft out through the gears toward the rear”, not a word about the bearings…
Any and all help appreciated. Hendrik.
gene bender
01-23-2008 01:47:28
 Re: Super A transmission, ball bearing removal in reply to Hendrik, 01-23-2008 01:36:18
I have replace a bunch of the front bearings and removed them without moving the shaft by prying carefully on the snapring. But i guess soner or later ill find one that doesent want to come off easy.
