F-20 right side brake lever
Scott Rukke
01-23-2008 05:27:23
Anyone have the casting number for a right side brake lever on an F-20?
LenNH
01-24-2008 09:14:07
 Re: F-20 right side brake lever in reply to Scott Rukke, 01-23-2008 05:27:23
From Parts Catalog TC-13-A: 2587D is "Countershaft brake lever, R.H. (Special)."
The "Handbrake ratchet bracket, R.H. (Special)" is 2586D. I have occasionally seen tractors with the R.H. lever, and I believe it is a little shorter than the left-hand lever 1809D. Hard to tell from the primitive drawings in the parts book.
Nebraska Cowman
01-23-2008 10:38:09
I could go out and look if it were warmer. the book calls for 2587D To be correct you also need the right hand latch.
Scott Rukke
01-23-2008 10:43:40
 Re: F-20 right side brake lever in reply to Nebraska Cowman, 01-23-2008 10:38:09
OK, the one I found has 1809D on it but it looks like it would go on the right side. Mine is broke off mid shaft so I suppose I could buy one and cut and weld.
