Order Farmall Cub Parts Online
Rear hub extensions for Farmall Cub
migraine
01-23-2008 09:41:38
I came across a pair of 8 inch rear hub extensions or spacers for a Farmall Cub. Were these made by I.H. as an option or an aftermarket item? These just bolt on to the hub and then the wheel is mounted on to the outside. Sorry if this a "should know it question" but didn't have any exposures to the Cub in my early days in Iowa.Thanks
Gene
01-23-2008 15:51:46
 Re: Rear hub extensions for Farmall Cub in reply to migraine, 01-23-2008 09:41:38
If they are IH part #: 355 066 R1 they are worth a number of dollars. There are also recent after market extensions available.
You can also put a set of duals on your Cub with a set.
migraine
01-24-2008 08:35:42
 Re: Rear hub extensions for Farmall Cub in reply to Gene, 01-23-2008 15:51:46
Thanks, I went and cleaned up the hub extensions this a.m and they are the numbers you listed. They are 6 inch not 8 as I said yesterday. Guess I'll decide what to do with them, maybe put duals on a Cub? Migraine
evilboweviel
01-24-2008 16:15:11
 Re: Rear hub extensions for Farmall Cub in reply to migraine, 01-24-2008 08:35:42
I have duals on a cub using them
have seen them sell lately for over $500 on ebay
Ron
mkirsch
01-23-2008 11:32:26
 Re: Rear hub extensions for Farmall Cub in reply to JayinNY, 01-23-2008 09:41:38
Actually, 8" extensions would be for the "high-clearance" option package.
As I understand it, the high clearance package is really high and WIDE. The front end is replaced with a unit that has a wider range of adjustment. Those wheel spacers are added. 15" front tires, and 36" rear tires complete the conversion.
gene bender
01-23-2008 10:08:35
Sounds interesting as to why you would need them when the rear is adjustable unless you would need a wider wheel tread.
K-Mo
01-23-2008 10:07:42
They are not extentions but an OEM option for installing rear duals.
K-Mo
