Clutch Throw-out bearing
FC Andy
01-23-2008 18:42:44
Does anybody know when replacing the throw-out bearing on a C if the bearing should press on to the casting that it rides on or should it be a slip fit or does it really Matter? The old bearing on mine pressed off, but the new one is just a "good" slip fit. Is that the way it should be? Or Should it press? Is there much clearance between it and the fingers on the clutch for it to fall off the diameter? (there is a relief diameter all the way up to the diameter the bearing seats on, for roughly 3/16". Thanks everybody for your input.-Andy
Janicholson
01-24-2008 09:02:22
 Re: Clutch Throw-out bearing in reply to FC Andy, 01-23-2008 18:42:44
I agree with the others, It should not move on its own from viabration etc. I would use locktite stud and bearing mount juice on it to prevent possible issues. Clean it well with a brake clean type cleaner to make nice adheasion. JimN
FC Andy
01-24-2008 13:07:46
 Re: Clutch Throw-out bearing in reply to Janicholson, 01-24-2008 09:02:22
Thanks for your imput, I think I will try using locktite. Andy
FC Andy
01-24-2008 05:18:45
There is just slight resistance when pushing the bearing on, it"s a snug fit, Just not a press fit.
Kevin Meier
01-23-2008 19:12:19
it shouldn"t be loose enough that it may slide and ride on the pressure plate levers. Does it slide up and down on it"s own or is there some resistance when putting it on?
