H Transmission back together (movie)
neblinc
01-24-2008 06:18:32
Well all the gears turn, it's a little hard to shift ; ) Audio/Video clip:H Transmission
GordoSD
01-25-2008 08:01:18
 Re: H Transmission back together (movie) in reply to neblinc, 01-24-2008 06:18:32
My6 old H manual shows three shims could be used. A regular, thin, or thick. I suppose combinations of these also. I would think that after years of wear you would need LESS shimming than originally installed.
Gordo
Doug C.
01-24-2008 08:27:29
Neat. I've been following your project - I seem to be one step behind you with my Super C. I put the transmission back in last night, and am waiting for my new bull cage o-rings so I can re-install the differential.
In the meantime, I've been thinking about shimming & gear adjustment. I'm going to start by putting everything back the way it was & see what I get. In your pictures, are you measuring side-to-side movement of the diff. with the dial indicator, or is that gear backlash? (I need to get a dial indicator).
Thanks, Doug
neblinc
01-24-2008 08:32:26
 Re: H Transmission back together (movie) in reply to Doug C., 01-24-2008 08:27:29
I used it for both. HF has the magnetic stand & dial indicator on sale for around $16, just bought mine last nite ; )
Came in handy for seeing what I was up against for tolerances.
Randy
brainerd dave
01-24-2008 06:27:27
The video's are completely excellent. Thanks.
Janicholson
01-24-2008 06:24:34
Very Cool. I hope the shimming info I posted made sense. JimN
neblinc
01-24-2008 06:38:52
 Re: H Transmission back together (movie) in reply to Janicholson, 01-24-2008 06:24:34
Yes it did Jim, the differential is out about .010 so it made it hard to adjust, but I think I got it.
Thanks
Randy
Janicholson
01-24-2008 06:54:31
 Re: H Transmission back together (movie) in reply to neblinc, 01-24-2008 06:38:52
You are a very careful and professional gentleman. I appreciate the dedication you place into your work. Thank you for careing for old Iron. JimN
