How do i remove a broken jet
NewHpuller
01-24-2008 08:51:51
On my 44 farmal H gas carb jet broke off at the top, the threaded part is stuck inside. Need some help!!!!
Maark
01-24-2008 15:44:48
 Re: How do i remove a broken jet in reply to NewHpuller, 01-24-2008 08:51:51
You may need to apply some heat to the area that the jet screws into. Let it cool the use the EZ Out or what ever works. I'm not a fan of EZ outs..
bc
01-24-2008 09:07:56
Hi, I just went through the same thing. I assume you mean the little jet that sticks up out of one of the two holes in the center of the carb next to the venturi. Just go buy a small ez out at ace hardware or about any tractor or auto supply store. It is a number 1 or 2 I forget. Costs about $3. Basically about the smallest one. Once I put the ez out in, it screwed out without any effort. It came out so easy that maybe a small screw started into it may hold while you back it out.
