Farmall Injectors
Dubl J
01-24-2008 14:53:05
What is the difference between these two injectors if anything at all? The one set came of a DT 361 and reads Bosch KBAL97SC 1/13 603. The other one off a D 361and it reads KBAL97SC 1/13 904. Is there a difference in them if so what is it. The tractor one of these sets is going in is a DT 361. Thanks
NDIHGUY
01-24-2008 20:13:11
 Re: Farmall Injectors in reply to Dubl J, 01-24-2008 14:53:05
Hey Guys, the D361 was a diesel 361 an 806 engine and the DT361 is a diesel turbo used in the 1206. I would think the DT361 would have larger nozzles. Just my 2 cents worth
K.B.-826
01-24-2008 15:08:25
All 361"s had the same injector body, so the difference from a D to a DT is probably the tips. One probably has more holes or different sized holes. Since they"re going into a DT, I"d say use the ones from the DT. If these are used injectors they should at least be tested first.
