240 engine swap
240Utility
01-24-2008 15:04:46
I recently purchased a 240 Utility tractor that was being used as a parts tractor. The engine is stuck and it is missing quite a few parts. I was wondering if the engine from an A or B would bolt up. I know that I would lose the hydraulics, but would it work otherwise?
Thanks
Stan(VA).
01-25-2008 12:44:46
 Re: 240 engine swap in reply to Stones Throw Farm, 01-24-2008 15:04:46
240U owner, Hal & Migraine,
I think the easiest way if he doesn't want to rebuild his block is to look for a 140 or 240 engine, either one should bolt right up.
The issue with the 340 block, I believe is more to do with the back end of the tractor being from the Super H/300/350 line which has a different bellhousing than the Super C/200/230/240/404 line. I'm not aware of any block differences between the Utility/Row crop versions (understanding that the 330/340 are hybrid versions to start with, their blocks definately different than the 300/350's).
The guy with the extra 340 block needs to look for a 330 or 340, poss a 504? And as has been mentioned before, the A/B is not a good idea as they don't have a mount for the hyd pump; the C/Super A/Super C/100/200/130/230 while possible, is not an easy bolt in swap because of the differences up front in the accy's and the radiator connections.
Stan(VA).
migraine
01-25-2008 08:40:55
 Re: 240 engine swap in reply to 240Utility, 01-24-2008 15:04:46
The row crop block does not bolt up in the utility version. I know because I tried to tell a gent here that a block from 340 utility would not bolt up in a Farmall 404. But he thought he knew better and spent 2000 bucks redoing the 340 motor only to find out it will not bolt up. Last time I saw it the 340 motor was hanging on a stand all redone and nowhere to go with it. Plus he already threw away parts from the 404 motor so he is hexed twice. A 404 Utility or 340 Utility (INTERNATIONAL instead of Farmall) should bolt up but I would do lots of measuring before I would make the deal. Migraine
El Toro
01-24-2008 16:32:28
I would find an engine off the Super C or the 340.
The later Super A's with the C123 engine too. Hal
