Hydraulics and water question
grizzthebear
01-24-2008 15:44:50
I was looking thro the parts manual today for my superA and noticed a hydraulic hose setup listed, but it doesn't show were it hooks up, is there another drop off on the tank and you add another spool valve or what? Mostly courious but i would like a tractor i can hook a cement mixer to and need a rear hydraulic setup.
It also showed a hydraulic creeper, what is it and were does it fit on the tractor.
I'm also wondering about adding a water pump, can you use one from a c123 on a c113 and are there any benifits or problems useing one on a thermal syphon engine?
Thx grumpy
gene bender
01-24-2008 16:42:57
 Re: Hydraulics and water question in reply to grizzthebear, 01-24-2008 15:44:50
You will need some ports added for aux hy. Yes you can put a water pump fro an C on your engine. Your HY pump will putout 1000 or more at 10gal flow if in good shape so you will need a hy motor that doesent need more than that for your mixer. The HYDRO-DRIVE is a hy motor that rons off the system on the PTO and will move the ground speed of the tractor with the clutch depressed. The stuff you want to do needs good knowledge of hy systems before you start so get all the info from the equipment before you try to make it work.
