Farmall H crankshaft question
Singlecylinder
01-24-2008 18:26:57
Can I use an older crankshaft in a newer engine if I replace the bearings with the correct size ones? Are the bearing outside dimensions the same on both engines so the bearings would fit in either block? Just the crankshaft journals different diameters?
D Slater
01-24-2008 18:53:11
 Re: Farmall H crankshaft question in reply to Singlecylinder, 01-24-2008 18:26:57
Yes
Joe H.
01-24-2008 18:41:06
straight H farmall cranks are all the same. I believe supers have a differnt stroke and larger journal sizes
Joe H.
01-24-2008 18:40:52
