Brakes growl on IH 706
jd720spec
01-24-2008 18:58:43
I have an International 706 with the D282 engine that I have rebuilt, the engine runs good and the clutch is good since I put a new clutch and pressure plate. The only thing that concerns me is that the brakes work but they make a loud growling noise when applied. The Hyd fluid has been changed as well as the filter. The tractor has sat for 15 years outside before I rebuilt the engine. I was thinking that the brake drums are just a little rusty and maybe need to be used to quite them down. They do work but make a loud growl when the brakes applied until the tractor stops moving. What is your suggestion remove the brakes and look inside?
or use the tractor for a while and see if it quiets down. It shifts fine in all the gears and pto works.
IaGary
01-25-2008 03:09:42
 Re: Brakes growl on IH 706 in reply to jd720spec, 01-24-2008 18:58:43
The brakes are most likely rusty as you thought.
Just keep running it but make sure the little weep hole in the bottom of the brake housing stays open. That little weep hole is there to let out brake dust and rust.You can clean it with a little screw driver.
If dust and rust build up inside the drum it will tear up the brake discs and the brakes will lock up.
The hole is a little slot right where the drum meets the rear end housing.
Gary
