Identifying the engine in an 886
Dirt Digger
01-25-2008 12:18:32
Just bought an 886. I don't know the year so how do i tell if i have the D360 or D358, it has a turbo if that helps?...thanks guys
-bryan
Dirt Digger
01-26-2008 11:36:36
 Re: Identifying the engine in an 886 in reply to Dirt Digger, 01-25-2008 12:18:32
did M&W make a turbo upgrade for this tractor too?
bradd
01-25-2008 14:27:47
360
Dirt Digger
01-25-2008 13:57:08
third party image
heres a picture of it
Lynn Davis
01-26-2008 10:11:45
 Re: Identifying the engine in an 886 in reply to Dirt Digger, 01-25-2008 13:57:08
If this is the "original engine" the 2 oil filters and the oil cooler visible in photo make it a 360, turbo not original equip. There will be serial# engine size stamped on flat above the injector pump just below the cylinder head, 414,436,466 are possibilities with a swap.
MNredfarmer
01-25-2008 13:39:15
 Re: Identifying the engine in an 886 in reply to Butch Kukulski, 01-25-2008 12:18:32
Dirt Digger said: (quoted from post at 13:18:32 01/25/08) Just bought an 886. I don't know the year so how do i tell if i have the D360 or D358, it has a turbo if that helps?...thanks guys
-bryan
The 360 would have a long cylinder oil cooler lying horizontally on the right side of the engine. The turbo must've been added by someone. I know a guy that put a 436 turbo in a 886 once, maybe they replaced an engine.
Tractor Jim
01-25-2008 13:03:45
886 did not have a Turbo
Dirt Digger
01-25-2008 13:51:37
 Re: Identifying the engine in an 886 in reply to Tractor Jim, 01-25-2008 13:03:45
this one does...its mounted right on top of the exhaust manifold...barely fits under the hood...theres a good chance it came off another tractor...it has a 3" exhaust outlet on the turbo
