340 to Electronic Ignition today
a_lead
01-26-2008 12:32:33
Removed the breaker ignition today and installed the Pertronix Electronic ignition along with a new Pertronix coil. The new coil is larger in diameter than the old, should have ordered a new bracket; will order next week.
Went in real easy following the instructions that it came with. Also opened the plug gaps to .040".
Don"t have a real load to put behind it to test, but it does seem to have more ommpf than before. Have a steep grade in the drive that I was able to climb in 5th with T/A back. Don"t think that I could have done that before the change.
Edward
NawlensGator
01-27-2008 04:00:33
 Re: 340 to Electronic Ignition today in reply to a_lead, 01-26-2008 12:32:33
Good job! I've been down that road 3 times now. Who would have thought you could have a 50 yr old tractor with elec ignition? I suggest you set the timing and note: it really is OK to open the plugs to 0.045".
