Super A final drive question
Greg-N-CA
01-26-2008 17:20:36
Can anyone help with the torque value for the rear axle bolt? Thanks, Greg
Daniel H.
01-27-2008 13:50:16
 Re: Super A final drive question in reply to Greg-N-CA, 01-26-2008 17:20:36
I have a copy of the seed plate drive instructions, which is held on by that bolt on the left side. It calls for 135 to 145 ft-lbs.
Hugh MacKay
01-27-2008 04:23:37
Greg: You've lost me, is this the bolt that holds axle in final drive or bolts that hold wheel on axle. I've looked through my IT manual and my IH Blue Ribbon service manual and see nothing re torque on either. It's been 45 years since I had a final drive apart, as I recall it was maximum pull on an 18" wrench handle, seems to have worked well. On the wheels I've been using a 24" handle on my bolts. I probably don't get anymore ft-lb on the 24" handle today than 18" 45 years ago, at least I sence that.
45 years ago, I could take the rear cast hub of a 560 from the ground and place it on the axle. I don't think I can do that anymore.
Greg-N-CA
01-27-2008 05:34:35
 Re: Super A final drive question in reply to Hugh MacKay, 01-27-2008 04:23:37
Hi Hugh, I'm putting my finals back together and I need to tighten the bolt holding the rear axle, bull gear, and bearings in the final drive housing. It's a 5/8 NF bolt and appears to only be a machine grade bolt. I want to be sure to have it tightened correctly before installing the cap. There are no specs in my manual either.
I can relate, the things I could do fifteen, twenty years ago and my abilities today are very different. What's up with that anyway?
Thanks, Greg
Hugh MacKay
01-27-2008 06:51:48
 Re: Super A final drive question in reply to Greg-N-CA, 01-27-2008 05:34:35
Greg: It may be we did too much of that, back when we were able.
teddy52food
01-27-2008 07:26:11
 Re: Super A final drive question in reply to Hugh MacKay, 01-27-2008 06:51:48
Yes, now I work twice as hard and get half as much done.
Greg-N-CA
01-27-2008 07:35:30
 Re: Super A final drive question in reply to teddy52food, 01-27-2008 07:26:11
There's some truth to that statement!
I looked up standard torque specifications and found a couple of web pages on the subject. It seems that I should be safe using 95 to 100 ft. lbs. for the axle bolt.
