int 340 gas utility wiring
tooltime
01-26-2008 18:36:38
i need to re-wire my tractor , the tractor was converted to 12volt neg/ground. i bought a new alternator,and there is a 2-wire connection on the alt, where do these wires come from on the tractor thanks
Janicholson
01-26-2008 19:03:51
 Re: int 340 gas utility wiring in reply to tooltime, 01-26-2008 18:36:38
Assuming it is a Delco,
The Terminal farthest from the big Power terminal hooks to the power terminal. The other terminal connects to the band end of a three amp diode, and then to the ignition terminal of the ignition switch. Or the diode could be replaced with a idiot light to do the same thing. The idiot light must be the same size as in the dash of a GM car with that alternator.
I recommend a 50 amp fuse link be placed in the main wire going to the amp gauge from the starter. Bob M has many pictures in the archives of delco W/diode. JimN
tooltime
01-26-2008 19:30:09
 Re: int 340 gas utility wiring in reply to Janicholson, 01-26-2008 19:03:51
thanks for the info. so if i understand this conversion from 6 to 12 volt, i do not need my voltage regulator that was on this tractor when it was a 6 volt system, i change that to a ballist resister/ THANKS
Janicholson
01-26-2008 19:53:36
 Re: int 340 gas utility wiring in reply to tooltime, 01-26-2008 19:30:09
The VR goes in the recycle bin. It has an internal VR in the new Alt. If you use the original coil (no reason not to) it will need a ballast resistor A chevy or chrysler late 60s car will have them (NAPA)
it goes between the coil and the ignition switch.
Bulbs must be changed in the lights, If it has a lighter it needs to be 12v. Use the same wattage bulbs as were in it, or parts in the light switch will fail. The big wire #10ga from the alternator will go directly to the Amp meter. Reverse the leads on the Amp meter, it is polarity sensitive and needs to have all its leads changed to the opposite side. Attach the #10ga wire to the terminal of the Amp meter that the key and light wire are attached to. Bob M wiring diagrams are good, but may not be specific to the 300U. They are informative look them up in the search for box. JimN
tooltime
01-27-2008 06:58:15
 Re: int 340 gas utility wiring in reply to Janicholson, 01-26-2008 19:53:36
thanks for all the info,it will help me
