Hydraulic leak on multi control body on 1206
John L Whorton
01-26-2008 18:50:10
Leaks when running at back corner of valve body.this seems to be a gasket leak.Is this a big job to put new gasket and what problems can I expect?
Kevin Meier
01-26-2008 19:51:48
 Re: Hydraulic leak on multi control body on 1206 in reply to John L Whorton, 01-26-2008 18:50:10
It"s not that big of a deal to replace the gaskets. There are 2. There is a plate on the backside and a gasket that splits the 2 parts. Plus the gasket between the plate and the tub.
MN Scott
01-26-2008 20:14:20
 Re: Hydraulic leak on multi control body on 1206 in reply to Kevin Meier, 01-26-2008 19:51:48
You have to measure the old rear gasket's thickness as there are differant thickness. The gasket is used to set the gear backlash for the pump.
