tractor speed
dennis repaal
01-27-2008 08:25:24
to my smarter than me freinds-how fast wiil a b farmall go down the road in high gear. the reason i ask is for going on tractor rides with the group. they usually go about 15 except when it rains then its every man for himself. would like to restore one. thank-you. dennis
ShaggyM
01-27-2008 18:03:54
 Re: tractor speed in reply to dennis repaal, 01-27-2008 08:25:24
I have a Super A that will run 22mph. It was checked by the Local law inforcement. I put a stiffer Governor spring and a pair of 11.2x24's on it. It runs 2000 rpm's and idles like a dream. Shaggy
jpl
01-27-2008 12:14:36
my uncles 101 jr would run 40 mph. yes, i was 16 and foolish. the engine blew and he had put a 6 cyl chrsyler eng out of auto in it, boy could i pull 2 16's, pulled in 2nd. had alot of fun with the old tractor, this was in early 50's. was tricle front too. glad the front was tight with no wiggles as i would have wrecked it on road.
GordoSD
01-27-2008 08:54:35
Best way to get your speed is to use a handhel GPS unit, and it will show you the route home!
Gordo
gene bender
01-27-2008 08:48:38
From the factory with 8x24 on 7in rims not qite 10mph WITH FACTORY SETTING. I use 11.2 on 8in rims and open up the gov to around 1700 and probably makes 15. We run in the 10mph class and dont have to run open. But i have ran in ride going 14 and keep up with no problems. Can be sped up more rpms with no problems as that engine will run more rpms without worry. The C with same engine new was set at 1615 factory. So what tires and rims do you have. I have a friend that has 10in rims and was clocked by radar with 15.5x24 at 17. There is a B that runs in WMT 14MPH group and they say he keeps up. He told me he didnt do anything thats the way it was when he bought it. So go out have a car follow and see what yours can do.
Nebraska Cowman
01-27-2008 08:40:06
No, your B won't keep up. 10 mph is top speed
