Tapping near Oil Filter on 656 Farmall 263 Gas
Jerry Gilliam
01-27-2008 15:00:12
I am beginning to hear a tapping noise near the oil filter or at least it seems with a rubber hose. Not real loud and at first you might think it is a noisey lifter. But the sound seems to be near the filter. Could it be a oil pump? The idiot light does not come on after starting up but as the engiene warms up to 190 degress and you let her idle, you can hear it. anyone had this problem or know what it might be? Thanks Jerry
Chuck's Repair
01-27-2008 19:02:26
 Re: Tapping near Oil Filter on 656 Farmall 263 Gas in reply to Jerry Gilliam, 01-27-2008 15:00:12
Try adjusting the valves first.The valve train is on that side of the engine. Chuck
Jerry Gilliam
01-27-2008 19:12:29
 Re: Tapping near Oil Filter on 656 Farmall 263 Gas in reply to Chuck's Repair, 01-27-2008 19:02:26
Thanks so much. I will adjust them according to the specs.
Jerry
