1 58280DA LOW, LOW SPEED ATTACHMENT (For tractors equipped with front wheel weight attachments 48600D and 48602D and power take-off attachments 49172DC, 56333D or 59374D) 1 60215DA SPEEDATT/Retired LOW, LOW SPEED ATTACHMENT (For tractors equipped with front wheel weight attachments 48600D and 48602D, less power take-off attachments, also for tractors equipped with power take-off attachment 59371D or 66369D) 1 65270DA LOW, LOW SPEED ATTACHMENT (For tractors equipped with front wheel weight attachments 48600D and 48602D and 7 MPH, fourth speed forward attachment 62397D) 1 65271DA LOW, LOW SPEED ATTACHMENT (For tractors equipped with front wheel weight attachments 48600D and 48602D and 7 MPH, fourth speed forward attachment 62397DB) 1 1 53232DA GEAR/Retired FIRST AND REVERSE SPEED SLIDING GEAR (53 teeth) 2 2 43312DA BUSHING REVERSE IDLER GEAR BUSHING 3 1 53231DAX GEAR/Retired REVERSE IDLER GEAR WITH 2 BUSHINGS, 43312DA 4 1 43303D BUSHING/Retired TRANSMISSION COUNTERSHAFT BUSHING 5 1 53230DAX GEAR/Retired TRANSMISSION COUNTERSHAFT AND FIRST SPEED DRIVING GEAR WITH BUSHING, 43303D 6 1 43328D BEARING TRANSMISSION COUNTERSHAFT BUSHING 7 1 60123DAX SHAFT/Retired TRANSMISSION COUNTERSHAFT AND FIRST SPEED DRIVING GEAR WITH BUSHING, 43328D 8 1 53228DA GEAR/Retired SECOND SPEED DRIVING GEAR (28 teeth) 9 1 58278DA GEAR/Retired THIRD AND FOURTH SPEED DRIVING GEAR (31 and 35 teeth) 9 1 65272DA GEAR/Retired THIRD AND FOURTH SPEED DRIVING GEAR (31 and 41 teeth) 10 3 117987 KEY TRANSMISSION COUNTERSHAFT KEY (Woodruff no. 27, 1/4 x 2-1/8") This is copied from the CNH on-line parts book. The list looks alot more complicated than my H parts book. However, I can't compare the two references because my H book is on loan.
I don't understand why they include the 3rd and 4th gear. Only 1st and 2nd are affected. This is due to the fact the regular 1st gear is a cluster gear (two gears -1st and 2nd- on one chunk of metal). The low-low second driving gear is a single gear. Click on the link to goto the low-low page. It may not open if you are not logged in. In that case, shorten the URL to goto home page and start from there. Enter Farmall H in search box.
