H Radiator
JUG
01-28-2008 09:27:20
my h is of the non pressurized system my problem is that it circulates coolant out the overflow tube till it starts running hot can i just plug the overflow or is something else wrong Thanks
Mike CA
01-28-2008 20:35:17
 Re: H Radiator in reply to JUG, 01-28-2008 09:27:20
CNKS said: Yes, both pressurized and non-pressurized H's and M's have thermostats.
How does a person know if their H is presurized or not? Especially when you've never had it running?
Red Mist
01-28-2008 15:43:17
Go buy a pressurized radiator cap. Install it and see what happens. After that - unless you are lucky - go ahead and find out what is wrong and fix it.
mike
CNKS
01-28-2008 17:27:58
 Re: H Radiator in reply to Red Mist, 01-28-2008 15:43:17
A pressurized cap will not fit a non-pressurized radiator. Pressurized cap has tongs that fit on the outside of the filler neck, non-pressurized cap attaches to the inside of the neck.
Red Mist
01-28-2008 19:28:51
 Re: H Radiator in reply to CNKS, 01-28-2008 17:27:58
Thanks, Jim. Didn't know that, having never had a non-pressurized H. mike
jal-SD
01-28-2008 13:42:29
Core is probably plugged-you should be able to cool an H with non-pressure radiator unless you are pulling the guts out of it. (My $0.02 worth. jal-SD)
JUG
01-28-2008 12:42:47
oil is not milky and it does not run hot until it circulates enough coolant out to be low could it still be a thermostat head gasket etc
old
01-28-2008 14:47:20
 Re: H Radiator in reply to JUG, 01-28-2008 12:42:47
Yes it could still be all of the things I said before because the head could be cracked in a way that water gets in to the combustion chamber and gets burned off same with the head gasket. An yes it could be the thermostat, because that only has to do with the cooling system. And it could also be a bad water pump
old
01-28-2008 10:37:59
You have some sort of problem if its doing that. Thermostat maybe be bad, a bad head gasket or cracked head or even a bad water pump. Pluging the over flow with just cause you more problem and still not fix the real problem
moonlite 37
01-28-2008 14:03:57
 Re: H Radiator in reply to old, 01-28-2008 10:37:59
Does a non pressured system have a thermostat? Just wondering
CNKS
01-28-2008 17:30:12
 Re: H Radiator in reply to moonlite 37, 01-28-2008 14:03:57
old
01-28-2008 14:34:13
Some do and some don't. All depends on the tractor and how it was made
Nebraska Cowman
01-28-2008 09:57:48
yes, something else is wrong.
