H running bad and spitting gas from carb bottom
Scott Rukke
01-28-2008 12:27:47
Started running real bad. Starts but no power, missing and sputtering and throttle won't rev up the engine at all. Also spitting gas from the bottom of the port in the carb. Only spits gas when running. I'm thinking float but wanted input before I split the carb.
Hoss in Maine
01-31-2008 14:18:57
 Re: H running bad and spitting gas from carb bottom in reply to Scott Rukke, 01-28-2008 12:27:47
A 6cyl h,hmmmmm. Later Hoss
bc
01-29-2008 08:28:46
The firing order is 1-5-3-6-2-4 if you want to check for plug wire pranksters. Could be kids, neighbors, your brother-in-law, or your coffee shop buddies.
They have this moisture removing spray you can get in a can that may help if there is moisture in the dist. You can check the dist. seal to see if it is ok.
I don't know if this will work, but you might try pulling one plug wire at a time while it is running to see if you can isolate which cylinder is the problem if there is a stuck valve. Then you could squirt some oil in the spark plug hole to lube it. For that matter it might not hurt to pull and check all the plugs and squirt some oil in all the cylinders.
I don't know if a blown intake manifold gasket would do the same thing or not.
Let us know what you find.
mkirsch
01-29-2008 05:00:52
 Re: H running bad and spitting gas from carb bottom in reply to CNKS, 01-28-2008 12:27:47
Scott Rukke said: (quoted from post at 19:21:19 01/28/08) No. It's behind a fence and no one is around. One day ran perfect and the next it didn't. It did start when the weather cooled down.
Those are perfect conditions for "pranksters." A car full of kids cruising by, nobody around, hop the fence, mess with some guy's tractor. Hilarity ensues...
Bob Kerr
01-28-2008 21:11:46
I will "third" the water in the dist cap and or stuck intake valve posts. squirt some kero or pb blaster or somekind of oil in the carb intake (take hose off) when it is running, it might come loose, but check for water first. If it sat at one time for a long while sometimes a valve spring will get weak on a valve that was held open when it was shut off before parking it so that may be something to check later down the road.
teddy52food
01-28-2008 18:04:32
Did someone pull a prank and switch a couple wires?
Scott Rukke
01-28-2008 18:21:19
 Re: H running bad and spitting gas from carb bottom in reply to teddy52food, 01-28-2008 18:04:32
Red Mist
01-28-2008 15:53:26
I agree with Glennster AND RustyFarmall AND Centaur. But..... you did not say - is there a lot of black smoke coming from the muffler whilst all this rude behavior from your engine is taking place? Black smoke means running rich; Running rich could be because of intermittant missing, OR because of something gone wrong in carb.
mike durhan
scott rukke
01-29-2008 05:07:59
 Re: H running bad and spitting gas from carb bottom in reply to Red Mist, 01-28-2008 15:53:26
No black smoke.
CENTAUR
01-28-2008 14:31:02
I agree with GLENNSTER and RUSTY FARMALL. CENTAUR
glennster
01-28-2008 12:35:32
sounds more like moisture in the distributor cap. pull the cap and peek inside. you can also try a timing lite and see if the mark is jumping all over when running.
RustyFarmall
01-28-2008 13:31:53
 Re: H running bad and spitting gas from carb bottom in reply to glennster, 01-28-2008 12:35:32
Or an intake valve stuck open.
