What would you offer
NCihcollector
01-28-2008 17:08:54
I have come across a 1947 Cub doesn"t run no battery, flat tires, no fuse, carb. has been taken off, has a drawbar, planter, disc, arms, and swinging drawbar.
Tractorfan1
01-29-2008 17:57:16
 Re: What would you offer in reply to steve crouse, 01-28-2008 17:08:54
And what is your problem? I bought my '48 Cub, that had sat outside for four years, but it wasn't stuck. A little tinkering and it fired right up. Can't keep a Farmall down. :wink:
Zach Bouchard
01-29-2008 14:58:41
 Re: What would you offer in reply to NCihcollector, 01-28-2008 17:08:54
If you don't know if it is stuck, assume it is.
NawlensGator
01-29-2008 08:36:39
I might go $650 depending on engine being free, amount of rust, and how much time and space I had to devote to it. Offer low and explain how you'll restore it to like new.
If the serial number is 3000 or below, it is one of about 2,500 known as 'circle cubs' which might be worth more to some people.
Andy Motteberg
01-28-2008 21:24:02
If motor is loose and it is complete, I think a fair price would be around $500-$600. If the motor is stuck, probably around $450.00.
Andy.
Zach Bouchard
01-28-2008 20:40:31
Depends if it is froze up. Maybe 400.
Mike CA
01-28-2008 20:38:33
 Re: What would you offer in reply to Larry NCKS, 01-28-2008 17:08:54
NCihcollector said: (quoted from post at 18:08:54 01/28/08) I have come across a 1947 Cub doesn"t run no battery, flat tires, no fuse, carb. has been taken off, has a drawbar, planter, disc, arms, and swinging drawbar.
Is the motor stuck? Scrap if it is. Add $100 if it isn't.
OldD-21Tractor
01-29-2008 08:35:24
 Re: What would you offer in reply to Mike CA, 01-28-2008 20:38:33
I agree Scrap it. Unless you some young kid and think you can save them all and know everthing. Oh Wait that is andy!
Andy Motteberg
01-28-2008 21:21:08
"Is the motor stuck? Scrap it if it is".
Why scrap it Mike?? You can free up a stuck engine. If a tractor has several bad problems and is not worth restoring, why not use it for parts? The parts will bring more than the tractor would in scrap.
Andy.
James Newton
01-28-2008 18:13:05
THE PLANTER ITSELF WOULD BRING MORE THEN 200.00 IF COMPLETE. I THINK 500 MIGHT NOT BE A BAD PRICE. OF COURSE YOU CAN START LOW AND COME UP.
Tractorfan1
01-28-2008 17:27:42
 Re: What would you offer in reply to RustyFarmall, 01-28-2008 17:08:54
For what you describe, with the added implements. It would be worth about $500.
Yugrotcart
01-28-2008 17:18:53
Scrap price is all it's worth, maybe $200.
Paul
