Drain for hydraulics on 300u
Jimer
01-29-2008 05:16:03
How is the hydraulic system to be drained on a 300u? I have been sucking mine out the top of the reservoir, is there a better or correct way of doing this?
Thank you for reading and any help.
Jim
bil b va a
01-30-2008 08:12:42
 Re: Drain for hydraulics on 300u in reply to Jimer, 01-29-2008 05:16:03
the drain plug is on the left side of the resevoir near the bottom. the filter is really a fine mesh strainer . cost a little over $100. i just replaced mine a coule of months ago
Jimer
01-29-2008 06:13:53
I should of added to the above post that I did find a small plug beside and slightly lower than the lines that run to/from the pump. It is too high to drain to the bottom of the reservoir and a mess to try to catch the fluid from.
Janicholson
01-29-2008 06:58:57
 Re: Drain for hydraulics on 300u in reply to Jimer, 01-29-2008 06:13:53
Jimer, I think that is it. The resivoir is the top of the seat added to the top of the trans. Make a small modeling clay lip that sticks to the casting under the hole, and sticks out to catch stuff in a pan/funnel. While this is in use, sticl a vinyl hose in the plug hole to finish draining into a container. (best I have).
when empty, put a close nipple and elbow in the hole with the original plug to allow a better system in the future. JimN
