h motor rebuild
Howard Junkin
01-29-2008 07:22:04
can you bore out a h block and put 300 or 350 pistons and sleves in?
thanks howard
N.D. Farmall H Puller
01-29-2008 07:52:04
 Re: h motor rebuild in reply to Howard Junkin, 01-29-2008 07:22:04
I bored mine out to take 3 9/16 in pistons
ChadS
01-29-2008 07:49:37
Yes. Use the 350 head gasket. Most kits come with firecrater pistons for the 175, if your going to run the H gas head, watch your piston to head clearence. On the manifold side of the compression chamber, the later model cyl heads had a "Slant" casted into the side of the chamber, which made room for the firecrater piston dome. H heads, have to have this slant cut into them so the pistons dont hit the head. Hope this helps, ChadS ChadS3@hotmail.com
L.C.Gray
01-29-2008 16:35:42
 Re: h motor rebuild in reply to ChadS, 01-29-2008 07:49:37
Perzactly right. I had to trim my H head to clear the firecraters on my 300 engine.
RustyFarmall
01-29-2008 07:48:19
The way I understand it is that some of the H blocks have enough meat in them to allow for over-boring, and some are thin enough that over-boring by that much will basically make a good paper weight out of the block. Don't know how to tell which is which.
ChadS
01-29-2008 08:18:24
 Re: h motor rebuild in reply to RustyFarmall, 01-29-2008 07:48:19
Ive seen the older blocks be that way. 39-42 blocks, you were pushing your luck at 3-3/4". Seemed like from 43 and newer they had more meat in em. M blocks,,, the older blocks, bad, newer blocks, good. Chad
RustyFarmall
01-29-2008 12:26:28
 Re: h motor rebuild in reply to ChadS, 01-29-2008 08:18:24
That must be what I was thinkin'.
