Farmall M rod lock washers
MJF
01-29-2008 10:19:45
Where can I find the lock washers that bend over the bolts for the for the Rod cap bolts on a farmall M. I'd hate to have to go to an IH dealer if i can get them somewhere cheaper Thanks
GordoSD
01-30-2008 05:24:16
 Re: Farmall M rod lock washers in reply to MJF, 01-29-2008 10:19:45
Or go with external tooth washers, or split lock washers.
Gordo
GordoSD
01-30-2008 05:23:38
Gordo
RR Mech
01-29-2008 20:28:45
Just torque them down an enjoy the rebuild. I dont think there has ever been a rod bolt that came loose that was torqued. None of the newer motors use any kind of locks. Some bolts may stretch or break but a lock is not going to prevent that anyway. Dont fret about it just enjoy.
Dave S.
01-29-2008 16:27:14
Bought some for a C-175 from IH and they are rather expensive for what they are.
MJF
01-29-2008 16:58:13
 Re: Farmall M rod lock washers in reply to Dave S., 01-29-2008 16:27:14
Thats what i was afraid of
Nebraska Cowman
01-29-2008 15:25:17
You could probably make some out of soft stock. Drill the holes first then saw it into short bits. You will only have to round the backside.
El Toro
01-29-2008 11:30:20
If the rod bolts have holes I would use twisted safety wire. The military has used this for years. Hal
MJF
01-29-2008 11:40:07
 Re: Farmall M rod lock washers in reply to El Toro, 01-29-2008 11:30:20
they don't haver the holes for wire, they had the tab that bends over them but when they came back from the machine shop they wasn't on there
El Toro
01-29-2008 11:54:18
 Re: Farmall M rod lock washers in reply to MJF, 01-29-2008 11:40:07
I would call the machine shop to see if they have the old locks. Hal
MJF
01-29-2008 16:06:41
 Re: Farmall M rod lock washers in reply to El Toro, 01-29-2008 11:54:18
It been a long time since the work was done and they don't have them anymore, thanks though
El Toro
01-29-2008 17:48:21
 Re: Farmall M rod lock washers in reply to MJF, 01-29-2008 16:06:41
Why don't you use lock nuts? They were used on some of their tractors. Hal
MJF
01-29-2008 18:06:06
 Re: Farmall M rod lock washers in reply to El Toro, 01-29-2008 17:48:21
They are bolts not nuts
