Head # 8060 DC ---What model?
migraine
01-29-2008 10:24:08
Just going through some parts I have in the other shop and found this head 8060DC. Is this off a Super M and is this a good head to use for pulling M or 450 Farmall? Found a head off a 300 175 engine and a head off 282 Diesel in there also. I think I need to hold a sale here!~ Migraine
james rumph
01-29-2008 14:20:53
 Re: Head # 8060 DC ---What model? in reply to migraine, 01-29-2008 10:24:08
The 8060 head is just a standard head " nothing special " about it . The high compression heads are the 400 and 450 with the LP versions having the smallest combustion chambers .
Alot of the 8060 heads crack threw the valve seat .
D Slater
01-29-2008 11:44:17
Those 8060 heads with the DC suffix started being used on very late gasoline M tractors and on SM, SMTA and super W series gasoline tractors. You should have no problem selling if not cracked. Some pullers want the later 400 and 450 gasoline and LP heads over your head though.
RustyFarmall
01-29-2008 10:56:01
The 8060 is the high compression gasoline head for a Farmall M.
