NEED RH SPINDLE FOR NORDEN WF ON A 560
Kellam
01-29-2008 13:39:22
TO ANYONE WHO CAN HELP OR INFO PLEASE CONTACT. I HAVE BEEN SEARCHING FOR THIS PART FOR MY FATHER IN IA. AND THIS SEEMS TO BE MY LAST HOPE. HIS RH SPINDLE IS BROKEN ON A NORDEN WIDE FRONT ON A FARMALL 560, HARD TO FIND!!!!! !!!
I WOULD APPRECIATE ANY INFO.! THANKS :)
Jim J
01-30-2008 19:59:36
 Re: NEED RH SPINDLE FOR NORDEN WF ON A 560 in reply to Kellam, 01-29-2008 13:39:22
I could possibly have one. The problem is I don't know when I will make back home to look.
Brownie450
01-30-2008 05:33:07
Shoup Mfg Co.
145S. West Ave. Kankakee, IL
WWW.shoupparts. com
Weld on spindles are on page 252 in the '06 catalog. Has all the dimensions.
Up North Louie
01-30-2008 03:52:05
Norden front ends are a trip to hell. I have two of them, one in need of re-hab. All State just laughs when you say Norden.
Who is Shoup?
Brownie450
01-30-2008 02:37:20
Check Shoup in Kankakee, IL to see if they might have the proper size for the hub. If the major spindle diameter is too large, it can be turned down at a machine shop.
RustyFarmall
01-29-2008 19:06:05
If that wide front was an original IH, or an aftermarket Schwartz, I could fix you right up. The Norden is a different story. Have you considered just replacing the Norden with a Schwartz? Might be just as easy and cheap as finding the parts you need.
Get ready for more fun!!
01-29-2008 17:25:56
Thats not all you will need. Get your welder mounted to that 2 point hitch!
Yugrotcart
01-29-2008 14:51:17
Here in Ontario we have a local machine shop that will make any spindle you need. Talk to your local tractor dealer, they may know of someone locally.
Paul
