farmall h manifold
farmerphil1
01-29-2008 19:14:26
I have an all fuel manifold for a farmall h that has a 1/2" hole in it. What is the best way to fix this? thank-you, Phil
Gauger
01-30-2008 17:59:30
 Re: farmall h manifold in reply to farmerphil1, 01-29-2008 19:14:26
Where is the hole located??
Michael Soldan
01-30-2008 05:23:59
The guys are correct, there is rod to do a good job and I had a manifold repaired...However...I bought a second H that needed manifold repair so I bought a new manifold..there is no comparison, a new manifold flows better, has no rust or pits to restrict and you have a much better distribution. That tractor runs much smoother than the one with the repaired manifold. A good weld job can be done but it is the condition of the inside of the manifold that you can't see that will restrict a good flow and distribution..my experience
scott rukke
01-29-2008 21:17:42
third party image
Cast is difficult but not impossible to weld. Problem is the contraction of the weld material after it cools. It tends to create cracks. There are several newer rods that are made specifically for cast that help with the cracking issue. They are expensive. Last time I priced them I had to buy at least 3# and it was about $60 for the rod. Whether it's weldable would depend on how it's broke and where. I have welded engines and manifolds using cast rod. I have also brazed them. In fact my distillate manifold on my F-20 had 2 cracked flanges and I brazed them. After grinding and painting you can't tell it was ever damaged. Find a good welder and let them take a look at it.
In the attached picture both the left and right flange were broken clean off. After beveling all the joints to get full penetration I clamped the pieces back on and brazed them with a bronze rod and flux using oxy-acetylene. Then I ground it back to its original shape and re-drilled the holes.
Andy Motteberg
01-29-2008 20:03:45
You can weld it, or have it welded by someone else. I myself don't really like welded up manifolds, so if yours has been repaired previously, I recommend finding a different manifold or a brand new one.
Andy.
ihc49er#2
01-29-2008 19:24:06
cant give you actual details, but you need a good welder guy. thats how i had some repaired.wheres them welders?
